Статьи Мосты КПП Режимы программирования коробок передач AutoShift EATON 1-го и 2-го поколения.
Shift Chart RPM Standard Economy
B-number:B-1xxx122501
Engine Governed Speed:1800 rpm
Engine Peak Torque:1200 rpm
Default Start Gear:2nd
Max Start Gear:5th
Skip Shifting:No
Throttle Modulated Shift Point:Yes
Shift Chart 2001 RPM Standard Economy
B-number: B-1xxx422501
Engine Governed Speed:2100 rpm
Max Start Gear:5th
Skip Shifting:No
Shift Chart 1800 RPM Perfomance
B-number:B-1xxx132501
Engine Peak Torque:1300 rpm
Max Start Gear:5th
Skip Shifting:No
Shift Chart 2100 RPM Standard Economy
Max Start Gear:5th
Skip Shifting:No
Shift Chart 2100 RPM Perfomance
B-number:B-1XXX432501
Max Start Gear:5th
Skip Shifting:No
